Oxygen sensor issue
Old Jan 22, 2013 | 02:51 PM
devinzmax's Avatar
Default Oxygen sensor issue
Hi everyone. I have a 2006 Honda Accord V6 AT from NYC. This weekend the check engine light came on. It's reading a "P0134" code with the AutoZone scanner tool. Can someone please tell me which sensor this is and maybe send me a diagram if possible? Also, if this easy to change or should I take it to the shop/dealer?
Thank you everyone..
Old Jan 22, 2013 | 04:26 PM
Dr. Drivability's Avatar
it's your bank 1, sensor 1 A/F ratio sensor heater circuit, (wide band oxygen sensor) bank one is the rear bank of the engine (closest to firewall)
Old Jan 23, 2013 | 07:32 AM
devinzmax's Avatar
Thank you. Is this hard to replace? If you or anyone else has a diagram please send.. I really would like to change this myself if I can.
Old Jan 23, 2013 | 08:32 AM
On the exhaust manifold back against the firewall, #9 is the sensor you want. Not sure, but it might be tucked back under the ventilation cowling??
Unplug the wire for that sensor & find the 2 same-color (black?) wires from the sensor. Measure resistance between those wires. Not sure what it's supposed to be, but a failed heater normally shows open-circuit.
If that heater element is OK then you're looking for problems in that circuit like maybe blown fuse or cut wire.
Old Jan 23, 2013 | 10:36 AM
devinzmax's Avatar
Thank you! I'll try to access this on the weekend.
3dw1n
Jan 14, 2015 01:53 AM
dmost30
Sep 8, 2008 12:42 AM
dmost30
mdjohn
Feb 18, 2006 04:28 PM
93AccordLX
Nov 21, 2005 09:22 AM
