P0118 Check Engine Light
Old Jan 29, 2020 | 03:50 PM
Jonathan Valencia's Avatar
Default P0118 Check Engine Light
Hey guys,
i have a 2010 Honda Accord EXL V6. Today I replaced the gaskets on my spool valve due to them leaking on my alternator. Once I reconnected everything I had to disconnected to get to it, I turned my car on and it started just fine. One problem though, my CEL light came on immediately. Ran the code scanner and it came back as P0118. Anybody have any idea if there is any correlation? Is it just the sensor? Any suggestions would be appreciated
Old Jan 29, 2020 | 04:06 PM
Seanjordan20's Avatar
Did you disconnect a coolant temp sensor and forgot to connect it back up or not all the way connected recheck the area and make sure all plugs are plugged back in all the way
Old Jan 29, 2020 | 04:22 PM
The sensor you're looking for is the one that sits just before your throttle body.
Old Jan 29, 2020 | 05:07 PM
just before the throttle body? Hmm, i thought I reconnected everything back correctly. I’ll double check. Is it this one I circled?
Old Jan 29, 2020 | 05:42 PM
Yes it is
Old Jan 29, 2020 | 06:05 PM
Yes it is
I thought I ensured I plugged it in. Could it be I also shorted it?
(I’m at work, so I can’t check until tomorrow . )
thanks again
Old Jan 29, 2020 | 06:21 PM
Yes it can be I'm just letting you know where to focus your efforts. Check the wires to make sure it's not broke.
Old Jan 30, 2020 | 02:12 PM
CEL is gone leal from my spool valve is also gone after new gaskets, some hondabond
thank you
Old Jan 30, 2020 | 02:32 PM
Did you forget to plug it back in?
Old Jan 30, 2020 | 03:06 PM
it was plugged in, not sure what happen there
i just disconnected it, then reconnected it, then started her up. CEL was gone
