P0420 Code - Catalytic Converter or O2 Sensor?
Old Oct 14, 2020 | 09:42 AM
Seanjordan20's Avatar
Check your #4 plug to see if there's oil or if you need new plugs. If all ok swap the coil to see if the misfire moves. If it does the coil is bad. At that mileage the coil should be good
Old Oct 14, 2020 | 05:01 PM
Ohenry's Avatar
Default Thank you.
the previous owner didn’t change the plugs so I’ll swap them all out and switch coils from 3&4 and see what happens. Thank you for the input. Any suggestions on the 420 or is this a contributing factor that needs to be addressed first.
At 2500 rpm
Old Oct 14, 2020 | 05:18 PM
Address first. You'll be able to tell if you need a new valve cover kit if there's oil on the plugs
Old Oct 14, 2020 | 08:00 PM
Ohenry's Avatar
Thank you. I’ll get this done Saturday.
Old Oct 15, 2020 | 01:00 PM
partialresponse's Avatar
Originally Posted by Ohenry
I just purchased a 2010 (172K miles) and was told the service engine light was on and the car would not accelerate but then it went away and the SEL went out. Pulled the codes last night. P0420 and P0304; #4 misfire. Cleared the codes and they came right back on subsequent scans. Any recommendations? I experienced the same O2 voltage as OP.
I replaced both oxygen sensors at about 140k miles, and after clearing the P0420 code it hasn’t reappeared in over 10k miles. Catalytic converter input and output temperatures were clearly not a good indication of the source of my P0420 code.
Old Oct 15, 2020 | 01:49 PM
Usually it's sensor 2 that's bad but I've had it come on before for misfires.
Life is an Odyssey
Jun 20, 2012 11:52 PM
draser
Mar 21, 2012 04:07 AM
FarrellT82
Jan 11, 2011 12:48 PM
FlyLow
Feb 7, 2008 01:03 PM
