PCV valve location on 95 Accord
Old Oct 2, 2007 | 07:28 PM
crvone's Avatar
Default PCV valve location on 95 Accord
Hi,
My car idles rough, so though I should replace the long ingnored PCV valve, but I don't know where it is located on 95 VTEC 4-cylinder.It woudl be great if there is a DIY write up onit, buyt I couldn;t find it... thanks in advance.
Old Oct 2, 2007 | 07:59 PM
white95's Avatar
Default RE: PCV valve location on 95 Accord
Middle of the valve cover opposite the plugs. L-shaped piece with a hose that runs to the intake manifold at the back of the engine. Pull it and shake it; if it rattles it's ok and you have a different problem. Or just replace it, their cheap.
Old Oct 2, 2007 | 09:31 PM
crvone's Avatar
Yes, thank I replaced it with a $5aftermarket one,my friendly Hondaparts department wanted 26 bucks for one! I just can't believe a simple part like this would be so much better just becuase it is from Honda!
Old Oct 2, 2007 | 09:54 PM
white95's Avatar
Did it correct your problem?
Old Oct 2, 2007 | 11:55 PM
crvone's Avatar
Not really, it still idles rough and somewhat low at stops.
I have new plugs/wires/distributor cap/rotor and air filter. I did a search and see people mention cleaining IACV. Not sure how to do this, couldn't find a DIY.
Old Oct 3, 2007 | 07:10 AM
2POINTautO's Avatar
You actually need to clean the throttle body, check the warm idle, if still not great the adjust manual idle adjustment, if still not great then get a diagnosis with scan data.
Do an oil change too, now, fuel fumes sucked into the PCV will make the plugs rich and give you a poor idle, take a look ot one of the plugs and let us know how black it is and how far down the white porceline is still white.
Old Oct 4, 2007 | 06:09 PM
crvone's Avatar
Actually, I may have spoken too soon. The PCV valve change may have done the trick, the car revs more smoothly now right aroung 750 ROM at idle.
By the way as mentione din my original note I ws chep and settled for aftermarket part (FRAM ) . I think it should be O.K., I figured I can replace the sucker 5 times if needed for the price of what dealer parts department wanted!
Old Oct 4, 2007 | 06:18 PM
2POINTautO's Avatar
At those prices, its a yearly tune up part anyways.
Old Oct 4, 2007 | 07:04 PM
white95's Avatar
Just an FYI:I've seen a lot of talk on another forum saying that the Advance Auto Fram copies are better than the actual Fram filters. I change my filter at every change so I just buy the cheapies.
If you clean any part of your intake I suggest you remove the part first. It took my car days to get all the garbage out; I cleaned everything while it was on the car.
hawaiian5
Jan 28, 2012 09:40 PM
sis00accord
Mar 22, 2011 08:50 AM
Rumplecat
Mar 5, 2011 07:09 PM
sashkarad
Feb 19, 2009 10:29 PM
Trake99
Dec 3, 2007 06:42 AM
