Performance chips
Sometimes it's a simple resistor to fool the engine temperature sensor. ECU thinks its cold, gives richer mixture. NOT good...
If it sounds too good to be true, it probably IS.
^ agreed. Even the expensive ones such as the Venom400 apparently merely trick your car into thinking it is running at Wide Open Throttle all the time. Not good in my opinion.
noboundaries6289
Feb 22, 2007 03:14 AM
