Persistent Code 9
Old Dec 6, 2010 | 08:00 PM
The way I eventually convinced myself the ECU was likely the problem was disconnecting the B (middle) connector at the ECU and measuring the CYP sensor resistance (orange, pin 11 and white, pin 12 wires) from that point. I got values of ~820 ohms, nearly same as I got at every other connector stage of the wiring harness.
Since you've replaced the ECU, I would check the sensor resistance as described above to check for a wiring fault or sensor fault. If you get out of spec values (too low or high), check closer (right fender shock tower) to the distributor, and finally at the distributor connector. If you get good sensor resistance at all those points, it would suggest an ECU fault as I had.
Old Jan 29, 2017 | 02:45 PM
Justin matthew's Avatar
I had a code 9 in my 94 accord, went threw 3 distributors, had the timing belt done and still the code came back, put a new ecu in and she runs like a champ.
Old Feb 23, 2023 | 03:08 PM
G Scott's Avatar
Default I’ve experienced Code 9 multiple times..
I have had a persistent code 9 (#1 Cylinder Position CYP Sensor Fault). This sensor is in the distributor.
Long story here. Several years ago, this code first appeared. I purchased a replacement distributor and problem was fixed for a long time, until this past summer, when problem reappeared (Code 9). Symptoms are rough starting, difficult start particulary on wet damp conditions. Once warmed and running, the symptoms disappear and CEL will not come on when started.
I now suspected a wiring fault, but checked sensor (good), and checked sensor from ECU connector in cabin, again good.
Not believing my ECU could be bad, I bought another distributor and again the problem seemed cured for a short time, but has again appeared after not using car for several days (now a spare to drive when I'm repairing something else).
I now believe my ECU must be intermittent w/ a cracked circuit or component.
My question: Does anybody see another possible fault I could investigate or diagnostic to perform?
Thanks
Try disconnecting the ECU then reconnect it. This cleared the Code9 and resolved the hesitation.
Paul S
Aug 19, 2013 08:02 PM
kevin1517
Sep 1, 2012 11:11 PM
DixonNxn
Aug 4, 2012 03:53 PM
Stener75
Jul 25, 2010 08:21 PM
madsteez
Jan 18, 2009 07:43 PM
