Please assist, h22 into a 95 ex problems
I have acquired a 1995 ex w/h22 swap. I have the two below CEL's.
14-IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor 22*- Accord Civic CRV CRX Del Sol Odyssey Prelude VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch I have the p13 ecu, what do I have to rewire/plugin or ground and reroute to make this car run like it should? Right now I have no VTEC and uneven idle if driven or if the AC is turned on. |
RE: Please assist, h22 into a 95 ex problems
Try PM'ing Live2Rice, he has an H22 swap.
You may want to take off the IACV and clean it out, or replace it. Also, the VTEC oil pressure switch has a screen that can get clogged. Are you low on oil? That can also cause VTEC issues. |
Thanks bro, will do both today once I get home (cleaning and oil change).
The VTEC oil pressure switch is a very common problem with this swap, I had this problem as well, there is a easy way around it however.
You will want to get some T taps, and a piece of wire, or just get a piece of wire and connect them, either way you want to have pin A4 of the ECU run to pin D6. This should fix your VTEC problem. As for the other problem try Finch's fix |
Tried the a4-d6 wire. No-go, the car wouldn't even start. Any other suggestions?
thanks again meek |
you sure, or is the P13 OBD2? if its obd1 this should work
http://www.phearable.net/tech/wiring/vtpsbypass.gif |
P13 is OBD1, it's from a 93-95 VTEC Prelude
ah yes thats right, cause the obd2 have the p5m
Woohoo! I have VTEC. Now to clean the IAT- will do this weekend when I go back to garage. Thank you guys so much!
| All times are GMT -5. The time now is 09:18 AM. |
