Please help** Rough Idle after Vtech Solenoid replacement
Old Apr 16, 2016 | 08:37 AM
pharaohe's Avatar
Default Please help** Rough Idle after Vtech Solenoid replacement
Hey guys. long time reader. new to posting. I need some REAL Accord expertise as I cant seem to figure this one out.
(sorry for the long read in advance. Ill try to keep it brief)
2008 Honda Accord EXL V6
So there was oil leaking somewhere around the Vtec solenoid and the oil was dripping into the alternator, so I had to get the Vtec solenoid replaced.
- mechanic ordered the Vtec solenoid from honda and replaced it.
- Right after the replacement, I picked up my car and noticed that on a cold start and when I come to a complete stop, the car's idle is very rough. It has a bass rumbling type vibration. It was idling hard enough for my buddy to sit in the car and ask "why is your car twerking" (lol) at a red light.
Mechanic asked that I bring it back to clean the throttle body, (which he didnt remove, but instead he cleaned the TB while it was still installed) and then he tried to do a (half ***) idle relearn procedure.
- both of these did not work. while driving the next day, the engine light came on and started flashing, so I had to drop it back off.
- car was with him for a week. he finally called me and said he THINKS he got it. He said he has to re-adjust some valves and that was it.
- went to pickup the car and noticed it was still idling rough. still felt the bassy rumbling vibrations but they was very low. it was idling much better than before, but def still not back to norm.
- it still has not thrown another engine light as yet, but the idle is still off. it annoys the hell out of me everytime I drive this car. Im even noticing a slight change in how the engine performs as well.
Once again, what was done:
- Vtec Solenoid replaced.
- (mechanic said) valves were adjusted
- I also had 6 new spark plugs installed, but no help.
- Throttle Body was cleaned (while installed on car)
- mechanic said he also let the car sit for an hour idling. no change.
Does anyone know what could be causing this all of a sudden? I know for a fact that the change is very noticeable. its like night and day. Its not idling high or anything, its warmed up and sits around 650/700RPM but its just vibrating. Rough idling.
Could the replacement of the Solenoid have anything to do with it? Is there anything (basic) I can do/check on my own at home to try and solve this issue? Steps for me to re-try the idle relearn procedure myself? ( I dont have a scanner though).
Car has been sitting overnight with both pos and neg battery cables disconnected. Im up early ready to go outside and work on this car so Ill keep my eyes on this forum. Thanks for the help guys I really appreciate it.
Old Apr 16, 2016 | 08:39 AM
pharaohe's Avatar
Old Apr 16, 2016 | 08:56 AM
What code were you getting before the vtec solenoid was replaced?
What were the Honda part numbers used for the replacement?
Old Apr 16, 2016 | 09:03 AM
pharaohe's Avatar
There was no code before the vtec solenoid. Actually before the solenoid replacement, everything was absolutely perfect. The rough idle and flashing engine light came after the solenoid was replaced.
And I apologize but to be honest I have no clue bud. Not sure what the code was was the CEL came on and I have no clue about the part number used for the replacement. All I did was take the car to the mechanic and he got the new solenoid from Honda and installed it.
Next time I will now document all details. You live you learn I guess.
Old Apr 16, 2016 | 09:15 AM
You may want to call the shop and ask them what code you had. Also find out if they have the old part. Replacement looks to be pretty simple, but you may want to inspect the electrical connections to the vtec.
Old Apr 16, 2016 | 09:41 AM
pharaohe's Avatar
good idea. I will call the mechanic and see if he recalls the code from the CEL. I know he doesnt have the old solenoid anymore as the job was done over a week ago. he said it was already disposed of.
Any tips on how to check the electrical connections to the Vtec? something I can do myself or it is something Id have to get a mech to look at?
Old Apr 16, 2016 | 10:03 AM
A quick check would be to unplug them and look at the pins for any corrosion or maybe oil inside. Definitely something you can do. Almost all honda electrical connectors have a plastic tab you have to push to release a clip while you pull the connector.
I'd recommend purchasing a shop manual for your accord. You can buy a pdf of the manual on automanualsource.com for around $22 and is worth the investment.
Old Apr 16, 2016 | 10:23 AM
pharaohe's Avatar
cool. thanks for responding I appreciate it
Old Apr 17, 2016 | 02:38 AM
holmesnmanny's Avatar
Unless he deliberately cleared the code, the code is still there. You need to have someone with a scanner pull the code. That should help point you to the problem.
Old Apr 17, 2016 | 08:16 AM
pharaohe's Avatar
well I know right after the solenoid replacement, the CEL came on and even started flashing. I had to take the car back to him and he said he had to re-adjust the valves and that made it better. The idle was better than before, but definitely not the same. It still had a rough idle to it except this time, it wasnt throwing the code. Its been like this for the past week. Better idle than before (when the CEL came on), but still idling rough. Definitely still an issue in there.
So wouldnt it throw a code again by now even he has cleared it a week ago? Or are you saying he could of deliberately deactivated it somehow so it doesnt come on period?
