PLEASE HELP!! 1990 Accord automatic steabelts!
Old Aug 2, 2007 | 03:59 AM
jay92889
Default PLEASE HELP!! 1990 Accord automatic steabelts!
Hey guys! I have a 1990 Accord Ex with automatic seatbelts whichno longer function. I believe something shorted out. Neither of the belts are responsive AT ALL, and the reminder chime that is supposed to sound when your belt is unhooked no longer chimes when they are unhooked either. There's clearly a problem with the entire belt system/door entry. At the exact same time as everything went wrong, the ignition keyhole light does not light up either! These all must be linked somehow, and I was curious how I could remedy this? Currently my driver's belt is stuck down, useless, and the passenger one isstuck up. =/
Please help! Is there a fuse or something that must be changed to get the belts, belt chime, and ignition light to function again? Thanks!
-Jay
Old Aug 2, 2007 | 07:14 AM
smaglik's Avatar
Default RE: PLEASE HELP!! 1990 Accord automatic steabelts!
might want to see a dealer. seatbelt stuff should be covered for the life of the car, unless its been tampered with.
Old Aug 2, 2007 | 08:41 AM
peaty
does the radio memory still hold your stations? there is a fuse in the engine bay that controls the seatbelts/radio/clock. i think its the 7.5 amp back up fuse. you might want to check that.
tom
Old Aug 2, 2007 | 09:04 AM
I'd checkALL the fuses. The seatbelt motors probably can't run thru a 7.5 amp circuit. I don't have a 1990 so I don't even know how many fuse boxes it has (engine compartment and under dashboard & ???).
Still, after you rule out blown fuses, don't forget the lifetime warranty on seatbelt systems.
Old Aug 2, 2007 | 02:15 PM
Carbon91EuroR's Avatar
it could be the number 1 fuse.the panel ison the far left drivers side behind the open hood latch.
Old Aug 2, 2007 | 02:36 PM
sir_nasty's Avatar
Look at the wires that run from the car into the door frame and make sure none of them got pinched or cut by the door. Open the door all the way up and look by the hinges
Old Aug 3, 2007 | 03:34 AM
jay92889
Great advice guys! Thanks a lot, it was a fuse as I had suspected. Tom was right, it's a 7.5A "radio backup" fuse, under the hood. It must be shared with the belts, belt reminder, and ignition light. Thanks again!
fading
Oct 15, 2012 09:20 PM
swingkid50
May 20, 2012 09:29 PM
alternety
Jan 3, 2011 07:54 PM
David Crevenston
Feb 4, 2010 04:39 PM
Ronnie101
Jun 21, 2007 09:44 PM
