Pls i need help- Honda accord 2001
Hi every body ,
I really need help with this issue , this car is costing a fortune to repair still no one had figured out what is the problem causing this ,,if any one of you lot had this problem or any one you know , and it was resolved succesfully pls help , I have a honda accord 2001 , it was running fine till 3 weeks ago when the engine light poped out of the dashboard! now the RPM does not go above 3000!!! either idle or moving,,, somtime when the engine is bit cold it will go above 3000 , but as soon the engine reaches normal temp ..same storey back,the car is automatic transmission ,4cylin... pls any one has seen this problem and resolved ,, do help and send me an answer pls ..... thanx
