Pls i need help- Honda accord 2001
Old Nov 3, 2011 | 03:22 AM
Moe's Avatar
Moe
Default Pls i need help- Honda accord 2001
Hi every body ,
I really need help with this issue , this car is costing a fortune to repair still no one had figured out what is the problem causing this ,,if any one of you lot had this problem or any one you know , and it was resolved succesfully pls help , I have a honda accord 2001 , it was running fine till 3 weeks ago when the engine light poped out of the dashboard! now the RPM does not go above 3000!!! either idle or moving,,, somtime when the engine is bit cold it will go above 3000 , but as soon the engine reaches normal temp ..same storey back,the car is automatic transmission ,4cylin... pls any one has seen this problem and resolved ,, do help and send me an answer pls ..... thanx
Old Nov 3, 2011 | 09:14 AM
Since you have a check engine light, you can get the trouble code read at Autozone for free. Then post the actual code(s) on this forum and we will go from there.
Old Nov 4, 2011 | 03:07 AM
Moe's Avatar
Moe
please UPUPUP UP UP ,,, loots of cheers ADMIN strators
iyhan
Dec 4, 2012 08:00 PM
MAXIM
May 16, 2012 03:51 PM
JDM_martinez_98
Feb 20, 2010 06:54 PM
Brig
Jan 10, 2008 06:24 PM
ckebottle
Jul 24, 2007 01:21 PM
