is it possible(Engine swap 4 cyl-V6)
Old Oct 15, 2006 | 05:48 PM
Trav20's Avatar
Default is it possible(Engine swap 4 cyl-V6)
As the title says is it possible to take the 4 cyl out of a car and put a V6 in the same car?
How much could it cost?
Old Oct 15, 2006 | 06:20 PM
acidflux's Avatar
Default RE: is it possible(Engine swap 4 cyl-V6)
hehe dude i had the EXACT same thought.. because they dont make 98 body shapes in manual transmisison with a v6 engine...
from what i asked sum1.. it IS possible but too costly and not worth it because the engine is a lot bigger and may require some component reconfig.. but i may be wrong..
Old Oct 15, 2006 | 10:01 PM
YeuEmMaiMai's Avatar
lets see...this is just what comes to mind
Instrument cluster
AC lines
radiator and cooling fans
Motor mounts(larger capacity)
Drive shafts
Transmission
Engine
ECU
Brakes and ABS module lines (front) and disks if they are drums in back
Suspension (you need heftier springs as V6 is 200lbs heavier)
Wheels (5 lug versus 4)
engine accessories (alt PS pump AC compressor)
Might need a new steering rack as well depending upon if the I4 one is in the way or not
Old Oct 16, 2006 | 09:41 AM
Trav20's Avatar
ok Nevermind then it's not worth it
Old Oct 16, 2006 | 08:11 PM
miki's Avatar
hehhee ,,, 2 much for 2 little gain. Better trade it in fot a V6. I made the same mestake but i made mine with transmission.
Wish I had an stick.
Old Oct 16, 2006 | 08:20 PM
sir_nasty's Avatar
I don't think I'll every buy another automatic for myself.... My wife is a different story she won't drive a manual... But as for me if it doesn't have a manual I don't want it
Old Oct 17, 2006 | 04:06 AM
deserthonda's Avatar
ORIGINAL: YeuEmMaiMai
Instrument cluster
AC lines
Drive shafts
Transmission
Engine
ECU
also don't forget that the engines are reversed,,,,, way way too much work + cost ,,like it was suggested you are better off to buy a v6 car outright
Old Oct 17, 2006 | 04:37 AM
I thought they flipped the K series around in the 7th gen....? so that both engines are on the same orientation........
Old Oct 17, 2006 | 04:41 AM
you are correct ,,,,,,,i guess i did not see the year and i just ASSUMED it was an earlier year ..
Old Oct 17, 2006 | 04:45 AM
ahha he did not say what year so I guessed as well... to be honest you cannot fit a V6 into a 94 or older accord or any I4 accord from 95-97 unless you cut off the whole front end and weld on the v6 one since it is 3" longer
