Possibly head gaskets????
Old Aug 24, 2022 | 05:08 PM
eddiewharton15's Avatar
Default Possibly head gaskets????
I have a 2001 Honda Accord 3.0 V6 , got home today shut car off heard a noise under the hood opened the hood and found coolant bubbling and coming out of reservoir and the top and bottom coolant hose’s are flat , I was thinking head gaskets but I’m not 100% sure didn’t check oil to see if it was milky or not , and car didn’t over heat either
Old Aug 24, 2022 | 08:03 PM
Did you notice any overheating issues recently?
Head gasket is possible. Could also be a bad radiator cap.
When the engine is cold, remove the radiator cap, and fill up the radiator. start the engine. Look for gas bubbles coming from the radiator.
If your engine starts overheating, turn on the heat in the car full blast to help cool the engine. I'd also keep some coolant in the car. Water will work in a pinch.
Old Aug 25, 2022 | 04:38 AM
There wasn’t any over heating issues , the gauge stayed where it normally does
Old Aug 25, 2022 | 09:02 AM
rockhoundrob's Avatar
Are the radiator fans working?
Old Aug 25, 2022 | 02:24 PM
Yes the radiator fans are working
eddiewharton15
Aug 24, 2022 05:07 PM
Shooter 58
Apr 5, 2015 03:47 PM
swifity5
Aug 13, 2014 01:48 PM
htownfanatic
Jun 24, 2007 09:54 PM
mdd0127
May 21, 2007 09:27 PM
