Power locks not working
Old Jan 18, 2020 | 03:22 PM
Capt.rick34953's Avatar
Default Power locks not working SOLVED
2015 accord lx door switchlock unlock or key fobs are not working. When key fob unlock is pressed the light flash as normal , when lock is depressed on key fob nothing happens. Fuses 19- thu 23 all have no power on them both sides. 19 -10 mp Passenger Side Door Unlock 20 -10 amp Driver Side Rear Door Unlock 21- 10 amp Driver’s Door Lock 22- 10 amp Passenger Side Door Lock 23 -10 amp Driver’s Door Unlock All have no power, all fuses are good. Problem with the Multiplex Integrated Control Unit (MICU) ???????
Old Jan 18, 2020 | 07:42 PM
Is this the only item acting strange in your car? Was any work done on the car before this problem occurred?
2015 is newer than my newest shop manual. The problem could be anywhere in the circuit.
Do you have a scanner that can read codes other than the check engine light codes?
You may want to stop at a parts store to see if their scanner can read vehicle-specific codes. You may want them to test your battery and alternator while you are there, because low voltage from the battery can cause strange issues.
Old Jan 18, 2020 | 10:09 PM
I’m new at this so please bear with me these are the two pictures from the scanner. Also I had a blown fuse in my My AC clutch. It’s a 2.4 L no issues with charging system. Thank you for all your responses and any help you can give me
Old Jan 18, 2020 | 10:13 PM
I took pictures of the scanner.. Like I said none of the fuses work/have no power all sides. Also blew a fuse on the AC clutch on the compressor. It is a 2 L engine.b I took pictures of the scanner.. Like I said none of the fuses work/have no power or sides. Also blew a fuse on the AC clutch on the compressor. It is a 2. 4
. Car is been flawless then all sudden lock switch on door will not operate open or close. And key fob does not respond to lock. But does flash tail lights in front courtesy lights one depressed unlock on key fob. Here are the pictures from the scanner. Thank you for any help you can give me. Car is been flawless then all sudden lock switch on door will not operate open or close. And key fob does not respond to lock. But does flash tail lights in front courtesy lights one depressed unlock on key fob. Here are the pictures from the scanner. Thank you for any help you can give me
Old Jan 18, 2020 | 10:48 PM
Seanjordan20's Avatar
Was anything done to the car prior. Does your high beams work. If not check fuse 12 under the hood should be a 30. You need to have your alternator checked and power/ground cables. You have a voltage issue somewhere
Old Jan 18, 2020 | 11:34 PM
I misread your first post about the fuses. The next step is to figure out what supplies power to the fuses that are missing power.
SeanJordan - is the 30 amp fuse 12 the 12V source for the non-powered fuses?
Old Jan 18, 2020 | 11:40 PM
It's hazy. I looked and it had 7 things on that fuse one of them being a fuse box. It wasn't clear so thats why I suggested it. It has to either be a fuse in the engine compartment or an electrical issue effecting the hole system (a power harness) but the harnesses rarely have issues unless there is something leaking or previous work done. I don't know what region the car sits so can't say rust
Old Jan 18, 2020 | 11:45 PM
This is what in seeing on 12
Old Jan 18, 2020 | 11:57 PM
This was a good read. Being that certain things aren't working it seems like the MICU is in a fail safe mode meaning it detected getting less than 10v at some point. The read is from a Honda Fit should be the same across the board
MICU
Old Jan 19, 2020 | 07:07 AM
I live Florida. Nice car has Zero corrosion. I did plug in 2006 trunk latch to trouble shoot. a trunk light Light . it lite up then unplugged and these issues started. i have a spare fuss box with a micu i will install and see if the issue clears.do not look like fun job. Then deal with the immobilizer.
