Power Locks problem 97 Accord
Old Jan 15, 2014 | 11:50 AM
daver1100's Avatar
Default Power Locks problem 97 Accord
Hi Accord folks- New to me 97 Accord SW, Power locks. When I use the key externally to lock the car, or use the lock button inside the car, I hear a power lock "sound", like it has activated (locked the doors), but none of the doors actually lock. I can lock the car by pushing all of the lock pins (things on the top of the door, don't know what they are called). Thought I'd throw this question out there before I start taking door panels off. Thanks! Dave
Old Jan 15, 2014 | 12:08 PM
It may be a loose ground wire running through the driver's door jamb or a problem with the power door lock control unit located in the driver's door. You can download the 94 Accord service manual (which is somewhat similar to your 97) in the Common DIY and Other Info. sticky at the top of this forum.
Old Jan 15, 2014 | 02:57 PM
daver1100's Avatar
Default door lock
Redbull- I figured the driver's door was probably the "master" of the system. If I pull a door panel to investigate, that's where I thought I'd start. Since it does make the motorized "click!" sound, I figured it was some mechanical malfunction and not a ground. The Control unit would probably be a pretty easy / cheap thing at my local U Pull It yard to try. Dave
Old Jan 15, 2014 | 03:08 PM
Is your Accord an SE, you typed SW in your first post?
If it is an SE, you don't have the power door lock control unit in the driver's door. You would have a keyless/security control unit under the passenger seat.
Old Jan 15, 2014 | 10:00 PM
daver1100's Avatar
Default locks
Red- it's a wagon, (SW) don't remember what designation- DX maybe? Cloth seats, no sunroof, no ABS, pretty basic really. does have electric windows.
My folks gave it to me at Christmas- so I'm coming over from the Volvo side.
Old Jan 15, 2014 | 10:09 PM
If it is a LX wagon, it has the standard power door lock control unit in the driver's door.
If it is an EX wagon, the keyless door lock control unit is under the driver's seat.
Old Jan 16, 2014 | 08:20 AM
daver1100's Avatar
Default Locks
Red- Just went out and looked- it's an LX. Standard set up as I figured. So I guess I'll pop the door panel off this weekend see if I can see anything. Thanks for the information.
I was on the Drive Accord forum for a while, but nobody ever replied to any of my posts. Guess I've found my home...Dave
ps- do people ever put leather seats in these Accords?
Old Jan 16, 2014 | 08:51 AM
Following diy may help:
https://www.hondaaccordforum.com/for...cycling-48713/
Leather seats were standard on EX models, so are available but expensive. There are aftermarket covers available that fit nicely.
Old Jan 16, 2014 | 02:23 PM
daver1100's Avatar
Default locks
Texas- thanks for that thread, sounds like just what I need! One question- does each door have this actuator or just the driver's door? Seems like the drivers is where I should start. Dave
Old Jan 16, 2014 | 02:26 PM
Each door has an actuator.
