Power Loss - hesitation
Old Nov 15, 2008 | 04:44 PM
grendel
Default Power Loss - hesitation
Hi,
I have a 1994 Accord LX, automatic with 420K miles. Recently (the last few weeks), it's begun to have a problem where at times it has great difficulty accelerating. When I step on the gas the RPMs actually drop and the car slows, threatening to stall if I keep pressing the gas. It may do this for several seconds or a few minutes, after which it seems to "break through" and drives normally again or, if I pull over and just let the car idle for a few seconds, I can then proceed again without the hesitation. This may occur several times on any given drive. During this time my gas mileage has also decreased sharply. The engine light has come on once or twice but mostly it doesn't.
My mechanic has replaced the rotor, wires, fuel filter, and cleaned the fuel injectors. He's also tested the fuel pump and it seems to have good pressure. He's cleaned the injectors twice and this seems to help for a day or two but then the issue recurs. At this point he seems to be stumped. I've also tried adding gas additives/cleaners to no avail.
Any ideas, advice would be greatly appreciated.
Old Nov 15, 2008 | 08:14 PM
Default RE: Power Loss - hesitation
Something is throwing the fuel/air mixture off. O2 sensor would be my guess, even if hasn't setcode. A coolant temp sensor, or manifold pressure sensor might cause this problem.
streetkit
Mar 28, 2011 01:50 PM
tstan
May 23, 2007 04:06 AM
mastar91169
May 10, 2007 01:24 PM
ctstar2000
Mar 27, 2007 08:10 PM
Dano
Oct 9, 2006 03:21 AM
