Power widow help
Old Apr 5, 2009 | 04:31 PM
Freeds
Default Power widow help
I have a 2003 2dr Accord EX V6 Navi that had intermittant problems with the drivers side window going down. It would usually work eventually now it won't go down at all. I bought a new power window reg/motor from HondaPartscheap.com and installed it - no change. The pass side works fine. I bought a used master switch assy - no change. I checked all the wires for continuity on the cable from the switch to the motor. No fuses are blown- as far as I can tell there are 20 amp fuses one for each window- both are ok the 50amp in the eng compart looks ok but I didn't ohm it out thinking if it were open neither window would work.
Is there any way to test my new and old motors by applying 12V
Please help.
Thanks,
Tom
Antarctica
Oct 5, 2010 08:33 PM
mamtsberg
Mar 17, 2010 09:15 PM
jwcorder
May 12, 2008 10:33 AM
Planefreak
Nov 15, 2007 02:52 PM
pyaarawala
Jun 29, 2007 02:06 PM
