power windows
Old Oct 16, 2007 | 03:44 AM
honda671's Avatar
Default power windows
i have a 95 accord lx,the problem is my power windows-all 4(four) opening my windows are alright but when it comes to closing them boy! they are very slow to close...can anyone out there let me know whats up with my power windows...i tried lube the guide rails but still..please anyone help!!!
rodney
Old Oct 16, 2007 | 08:29 AM
falkore24's Avatar
Default RE: power windows
clean the tracks, then lube them. Alcohol, a sponge and paper towels.
Old Oct 16, 2007 | 01:37 PM
deserthonda's Avatar
ORIGINAL: falkore24
if this does not help you might have to replace the run channels,
Another thing you can try is to move the run channel guides a bit apart,, need to remove the door panel to do so, but loosen up the 10mm bolt at bottom of guides and push them a bit toward frt of car ( frt guide ) and back ( rear guide ) this will give window a bit more play ..
DO NOT spread them too much apart or window will go up a bit crooked specially at top of tracks
Old Oct 17, 2007 | 05:01 AM
honda671's Avatar
i will try out your advice and thank you
Old Oct 17, 2007 | 02:23 PM
falkore24's Avatar
also, please post a signature and write smaller
Old Oct 18, 2007 | 03:50 AM
honda671's Avatar
the heck with you falkore i did not ask you or forced you to reply
**Please do not use any harsh words in the forums and >>Yes Please put your information in the signature section for everyone to see, it helps folks know what kind of car you have when they reply to any questions you have..**
Old Oct 18, 2007 | 06:42 AM
falkore24's Avatar
well that's uncalled for.
Old Oct 18, 2007 | 03:32 PM
19Accord97
ORIGINAL: honda671
the HECK**with you falkore i did not ask you or forced you to reply
Uhhh.... when you post a thread you are asking everyone to reply.
Totally uncalled for, and if that is how you will act on this forum when knowledgeable people are trying to help you, we would prefer you to leave or clean up your act.
Old Oct 19, 2007 | 08:52 AM
white95's Avatar
Since this guy is being a *******, I'm highjacking this thread...
My 95 LX has the same problem and the wipers run slow also. I have cleaned the window tracks but I think the multiple motors running slow is related. My little battery tester/charger says that the battery and alternator are fine, though I don't totally trust that. Load detection was also tested in accordance (no pun intended) with a Haynes manual and checked ok. Has anyone else had this problem?
Old Oct 19, 2007 | 12:01 PM
falkore24's Avatar
try the accessories while giving the car a little gas. It sounds like your battery is on it's way out. If you don't really trust your tester, Autozone can load test your charging system and battery and I believe it's free.
