Primary 02 Sensor 96 accord 5 speed
Old Feb 13, 2010 | 07:04 PM
efster420's Avatar
Default Primary 02 Sensor 96 accord 5 speed
Need help locating the primary sensor on my 96 accord 5 speed vtec f22b engine
Any pictures would help out alot
Old Feb 13, 2010 | 09:52 PM
I guess it's an EX? The front O2 sensor is further down the exhaust pipe, behind the oil pan, but before the catalyst. It's #31 here, just after the 2 pipes join together into 1.
Old Feb 14, 2010 | 02:19 AM
efster420's Avatar
yes ex i need help locating both 02 sensors i located the primary one but my check engine is marking front and rear and i have no clue were the rear one is located
Old Feb 14, 2010 | 03:08 PM
Exclamation
One is in front of the converter and the other is behind the converter.
Replace both to make it right...
Old Feb 14, 2010 | 03:16 PM
Arrow Here's Some Info For You
According to my Honda Manual..it reads that the 1992 to 1995 Accord has the F22B engine...you said you have a 1996..?
Please correct me if I'm wrong
Old Feb 14, 2010 | 09:07 PM
In that picture (1996 Accord EX 4-door 5-speed) the front sensor is #31, the rear sensor is #32.
The rear sensor is actually screwed into the side of the cat, which is #3. The picture is a bit funny, because the rear sensor is actually LOCATED about where part #50 is shown.
Old Feb 16, 2010 | 12:32 AM
efster420's Avatar
i have no clue the car is salvaged ne one has a clue why vtec isnt working
Old Feb 16, 2010 | 12:35 AM
efster420's Avatar
onn all the dmv papers it says its a 96
Old Feb 16, 2010 | 01:03 AM
The 96-97 engines are f22b engines too. Angelo, maybe your manual was printed in 1995?
Did you find both O2 sensors?
Old Feb 16, 2010 | 01:53 AM
Lightbulb Thank You
Thanks for pointing that Jimmy..always helps to make things easier when you chime in
Attached Thumbnails Primary 02 Sensor 96 accord 5 speed-0910poster_1280x960.jpg
