pulley noise
Old Jan 10, 2018 | 11:10 AM
frisbie's Avatar
Default pulley noise
I have an '04 accord v6. I recently replaced my alternator and drive belt. After a couple of months, the idler pulley started squealing and I had it replaced, then I replaced the tensioner assembly. A few days later it sounds like my power steering pulley is a new culprit. Has this happened to anyone else? Do I need to replace the power steering pump, or just the pulley?
Old Jan 12, 2018 | 09:42 PM
I think the bearing under the pulley is part of the drive shaft of the power steering pump. The pump likely needs to be replaced.
It is strange that the pulleys are squealing after the alternator replacement. Is it possible the alternator pulley is out of line? Is there any damage on the new drive belt?
Old Jan 14, 2018 | 09:06 AM
If you use a bit of belt dressing and it gets quiet, then you know it's the belt sqeaking not the bearings.
papajimmm
Jul 10, 2012 12:38 PM
zann121
Jul 9, 2009 04:57 PM
Medina_Complex
Feb 19, 2009 08:07 PM
accordfan222
Oct 14, 2007 07:19 AM
igotjshoe
Jun 6, 2005 10:50 PM
