Question about changing engine oil
Old Feb 29, 2012 | 10:31 PM
rubberducky101's Avatar
My friend suggested I used cinder blocks after jacking it up, is that a good substitute for ramps since they are a bit cheaper.
Old Feb 29, 2012 | 11:03 PM
You stated you had jack stands, use those after jacking up the car to support the car. Cinder blocks may collapse under the weight of the car, dangerous imo.
Old Mar 1, 2012 | 07:32 AM
"Cinder" blocks are dangerous because it's a "brittle-fracture" material. It can suddenly crack & crumble without warning.
Old Mar 1, 2012 | 09:02 AM
Jet sitter's Avatar
IMO, buy the ramps. Three reason's come to mind: safety, convenience, and ease of maintenance.
Old Mar 1, 2012 | 05:44 PM
Sorry what I meant to say was can I put them under the wheels, with the car jacked up of course, as an extra layer of safety in case of the jacks lowered?
Old Mar 1, 2012 | 05:47 PM
Are they cheaper than the jacks? cause I already spent $65 on a kit which includes 2 jack stands, 1 floor jack, and 1 creeper from autozone.
Old Mar 1, 2012 | 06:34 PM
  #17
Jet sitter's Avatar
$29.00 at WalMart. You don't need a stand, jack, or creeper and they are safer and easier to use.
Old Mar 1, 2012 | 10:05 PM
  #18
He's already got jack AND STANDS. Ramps are a little easier for a few things where you don't need to take off the wheels, but stands are more useful for more different jobs.
Just don't get underneath with ONLY the jack. They can let the car down onto you if the valve decides to leak a bit. That's what the stands are for.
Old Mar 3, 2012 | 09:51 AM
  #19
Jet sitter's Avatar
So, have you changed your oil?
Old Mar 4, 2012 | 06:35 PM
  #20
Sadly no, I can't find the jacking spot on the front end of the accord. Whenever I try to jack it up the frame goes up but the wheels doesn't come up with it
