Question about some parts new vs used + other things
Old Aug 9, 2016 | 08:52 PM
bladest's Avatar
Default Question about some parts new vs used + other things
hi people i have old honda accord year 1993 petrol 2.0is 131hp european model engine f20z1 , my master cylinder and i guess slave began to fail i use after market chinese and i am tired of them i used after market ialian they fail after 6 months chinese lasted me for 2 years, do u think its worth to buy Brand new original genuine parts master and slave for my ancient car? Price is very high both cost like 300$ with labor, in the paste i used 2nd they fail quick and new after market too, so i dont know what to do? My other question is which is better to buy new or second hand Master brake cylinder ,if i change the master cylinder with better one for example my car master cylinder is 3/4" facelift same car have 1" master cylinder if i get face lift master cylinder will i receive better stopping distance? Or nothing will improve? Is it better new or 2nd hand ? My brake pads,brake disks, are new brake pipes too, brake fluid too, calipers are well taken care of. Please advice!
Old Aug 9, 2016 | 10:26 PM
Most aftermarket parts are not better than OEM parts in my opinion. At best aftermarket parts are the same. The cost difference is what I consider.
I don't know why your master and slave cylinders are failing. It could be the machining of the cylinder or the rubber cup seals and springs.
It is a tough call on the best plan. You may want to consider a used OEM Honda part that doesn't look corroded in the bore and find a decent rebuild kit.
I'm not sure what improvement you would get with a 1 inch bore. I typically stick with a stock setup with my repairs.
Old Aug 10, 2016 | 08:42 AM
A larger bore master cylinder will require more force at the pedal to do the same job. Unless you use the corresponding larger-bore calipers/wheelcylinders to match.
Hicksvilleshick
Aug 13, 2015 11:40 AM
jaybee74
Apr 26, 2014 12:19 AM
LordAccord
North East
Sep 29, 2012 01:42 PM
HondaAccordEX94
Mar 11, 2010 04:21 PM
Sweagle02
Dec 31, 2008 10:26 AM
