Rack and Pinion needs replacement - 95 wagon
Old May 8, 2022 | 03:50 PM
How2's Avatar
Default Rack and Pinion needs replacement - 95 wagon
Hello
I would like to know what re manufactures to stay away from and which have a proven reliability track record
The driver side wheel has slop ,vibration at low speed. The problem is in slop the Rack and Pinion on that side only
Wheels have been re-balance. rims are straight
Who is the best source for the part?
H2
Old May 9, 2022 | 04:58 PM
I haven't seen too many issues with the PS rack and pinion on here. Getting one from the dealership is the best option, but will be very expensive.
Do you see any signs of PS fluid leaks or are you losing PS fluid?
Are you sure the rack is the issue vs the inner tie-rod joints? It may be worthwhile to pull back the boot to inspect the inner joints for excessive play vs the rack itself. I'd use a zip tie to re-secure the boot.
Old May 9, 2022 | 05:01 PM
There is also a good ericthecarguy video on youtube you may want to watch.
Search for:
1999 Civic Power Steering Rack Replacement (Part 1) - EricTheCarGuy
Khaj
Feb 6, 2016 09:52 AM
3ringcircus
Feb 19, 2012 08:23 PM
ehauptma
Jun 12, 2010 12:46 AM
jay81
Jun 10, 2008 03:22 PM
liam71234
Oct 7, 2007 09:54 AM
