Radiator Capacity for 1996 Ex 4cyl. Auto
Old May 23, 2010 | 01:19 PM
Accord_Ras's Avatar
Default Radiator Capacity for 1996 Ex 4cyl. Auto
I have searched high and low without success. Can anyone assist? Coolant capacity of radiator alone.
Old May 23, 2010 | 01:39 PM
Question About-Maybe ?
Try putting in 7 Quarts if it's dry then run it and then top it off..or try looking it up in the search forum..
Attached Thumbnails Radiator Capacity for  1996 Ex 4cyl. Auto-100_0858pt1005.jpg
All the specs I've ever seen give the total capacity (about 7 quarts) not just the radiator.
Old May 23, 2010 | 02:21 PM
Accord_Ras's Avatar
Ok...let me further explain. I presently have the Rad out of the car...I suspect a partial blockage. I'm giving the white distilled vinegar a shot to see if it will clear any blockage. The Rad is accepting less than a quart of the vinegar, hence my question.
If I knew the capacity of the Rad it would give me some idea of the severity of any blockage.
Old May 23, 2010 | 03:59 PM
Seems like it should take a lot more than a quart, but that's just a WAG.
You could also run a garden hose to see how it handles all that water flowing through.
Old May 23, 2010 | 04:39 PM
Accord_Ras's Avatar
I've already done the garden hose stunt....that's what led me to the partial blockage theory. The flow-thru was somewhat restricted and a back-flush did not improve things.
It is really amazing that after scouring the 'Net this info remains elusive
Old May 23, 2010 | 07:45 PM
deserthonda's Avatar
when you drain and refill the radiator, it takes around 3 qts,,, but to be honest with you i do not know the exact amount cause i just fill it till it is full and bleed it ..
Old May 23, 2010 | 09:22 PM
Accord_Ras's Avatar
That sounds reasonable. Extrapolating from that, and estimating the capacity of the lower and upper hoses and partial block drainage, the rad should be around a quart. Seems kinda tight that only that amount of coolant is being cooled, at discrete intervals, during the flow cycle
Old May 26, 2010 | 04:03 PM
Accord_Ras's Avatar
Overheating problem solved. The rad was partially blocked. White distilled vinegar (soaked overnight) cleared up everything nicely. The capacity of the rad is just about a quart. Now temp is stabilized at just above a quarter.
Old May 26, 2010 | 04:28 PM
Excellent. Thanks for posting the final result.
