Radiator fan trouble..
Hi I'm having problems with my fan, 94 accord ex..was working perfect 1 week ago, now it doesn't come on. The fan works if I run it directly to the battery, my car was overheating so I thought my fan went, since it's not that, we bought a new thermostat, ect sensor, also I think it's ac relay under the hood by the fuses, still no fan - we tried jumping the green connector looking thingy, there's 2 of them on the left side of engine, sorry I don't know much about cars, any help/suggestions would be much appreciated thanks..
Crispin is correct, there is also a post by Jim in the "Common DIY Threads" sticky at the top of this section describing the sensors and their function.......I'll give a slight hint.
Green connector near the t-stat housing, lower hose. Key to on-engine does not need to be running, pull the connector off, use a paperclip or something and jump the "wire connector" side of the connector. BOTH fans should come on.
Novaknowledgenow
May 30, 2013 08:58 PM
