Random backfire through intake
Old Jul 25, 2016 | 08:28 PM
Accordnation's Avatar
Default Random backfire through intake
I have a 96 accord lx f22b2 5spd when I go to take Off sometimes it will backfire through intake I checked everything there's no codes I checked timing its where is supposed to be it doesn't do it all the time it's just random anyone run into this problem and was able to fix?
Here's what I done so far plugs replaced ,ignition coil replaced, distributor cap and rotor button ,I only run premium I keep injectors cleaned using fuel service treatment by Wynn and keep the throttle body clean atleast every 6 months and I use 5w-30 synthetic blend oil .
Old Jul 25, 2016 | 10:41 PM
Prospector's Avatar
I would not think that premium fuel to be necessary for the LX, certainly 86 octane should be sufficient
Old Jul 26, 2016 | 07:51 AM
shipo's Avatar
Three possibilities:
  • The timing is far too advanced compared to factory spec.
  • The timing belt jumped a tooth.
  • One or more burned intake valves.
Old Jul 26, 2016 | 11:16 AM
Now says its one of the three possibilities wouldn't it do it all the time not just randomly
Old Jul 26, 2016 | 11:34 AM
I'm moving this over to General Tech. The "new member" forum is mostly for welcome & introductions.
Old Jul 26, 2016 | 12:12 PM
shipo's Avatar
Initially, no, but as time goes on the issue should worsen.
Old Jul 26, 2016 | 12:19 PM
Running premium won't help your engine. You can save money by using regular octane and run the fuel injector cleaner occasionally.
My suggestion to diagnose the problem is to take a look at the PCM data. The 96 accord was first to get an OBD2 connector that is behind the ashtray. You may want to purchase a cheap scanner or a bluetooth OBD2 reader and monitor with your cell phone.
Old Jul 26, 2016 | 02:18 PM
It's been doin since I bought the car and I bought two years ago and it haven't gotten worse
Old Jul 26, 2016 | 02:21 PM
To be honest with u I save more money using premium it cost less to fill up with premium than regular or mid-grade it cost me 30 to fill up with regular before and since I been using premium it only cost no more than $22 and I only get my fuel from one gas station it's bp
Old Jul 26, 2016 | 02:23 PM
I have looked at the data using my scan tool I have I checked for misfires and it didn't do it while I had the scan tool connected and was driving not once did it backfire
