Rapid Turn Signal Issue 2005 Honda Accord LX
My left turn signal flashes rapidly while my right turn signal flashes at the normal speed.
When I put my hazards on, they both flash at the normal speed. I changed the bulb and the problem persisted. I replaced the bulb socket with a brand new one and the problem persisted. I replaced the relay under the dash with a brand new one and the problem persisted. what else can I do? thank you, eashan 2005 Honda Accord LX |
Which bulb/socket did you replace/repair, the front driver's side, rear driver's side, or both?
Originally Posted by PAhonda
(Post 397355)
Turn on the hazards and look at the rear driver's side blinker. It could be burnt out or weak causing the rapid flashing. Check the socket for any obvious corrosion.
(Post 397365)
