Rapid Turn Signal Issue 2005 Honda Accord LX
Old Jun 12, 2022 | 07:17 PM
eashlo88's Avatar
Default Rapid Turn Signal Issue 2005 Honda Accord LX
My left turn signal flashes rapidly while my right turn signal flashes at the normal speed.
When I put my hazards on, they both flash at the normal speed.
I changed the bulb and the problem persisted.
I replaced the bulb socket with a brand new one and the problem persisted.
I replaced the relay under the dash with a brand new one and the problem persisted.
what else can I do?
thank you,
eashan
Old Jun 13, 2022 | 05:09 PM
Which bulb/socket did you replace/repair, the front driver's side, rear driver's side, or both?
Old Jun 15, 2022 | 05:55 AM
eashlo88's Avatar
just the Front drivers side
Old Jun 15, 2022 | 05:32 PM
Turn on the hazards and look at the rear driver's side blinker. It could be burnt out or weak causing the rapid flashing. Check the socket for any obvious corrosion.
Old Jul 29, 2022 | 10:15 AM
eashlo88's Avatar
I removed the drivers side rear bulb and bulb socket and the problem persists…
Rj2
Oct 25, 2013 12:37 PM
polaris80
Feb 14, 2013 08:50 PM
Damondelong
Jun 11, 2012 05:21 PM
jellero
Sep 18, 2011 05:55 PM
88accord
Nov 29, 2006 07:35 PM
