Rattle coming from rear deck - 2012 EXL V6
Old Sep 25, 2011 | 02:37 PM
TonyC2012's Avatar
Default Rattle coming from rear deck - 2012 EXL V6
I just bought a 2012 Accord EXL V6. I love the car but a rattle coming from the rear deck near the center speaker is driving me crazy. It's not being caused by bass, although I can duplicate the noise by cranking up the sub. The sound also occurs with the stereo off when I'm driving. Anyone else experience this? I have seen others talk about it with slightly older models. Anyone have a solution?
Old Sep 25, 2011 | 03:33 PM
The Honda technical service bulletin for the rear shelf rattle on rough roads:
"http://mordor.rutgers.edu/accord/tsb/08-09%20rear%20shelf%20rattle%20on%20rough%20roads%20 08-083.pdf"
For rattle with bass:
"http://mordor.rutgers.edu/accord/tsb/08%20rear%20shelf%20rattle%20with%20bass%2008-074.pdf"
Old Sep 25, 2011 | 04:27 PM
TonyC2012's Avatar
Thanks for the reply, but neither of those links work
Old Sep 25, 2011 | 04:37 PM
The forum rules and policies doesn't allow live links. Copy and paste the links without the quotation marks ( " " ).
Old Sep 25, 2011 | 06:29 PM
TonyC2012's Avatar
Ahh finally figured it out. Thanks!
Old Oct 2, 2011 | 08:31 AM
kendo's Avatar
i got the same problem,how did you solve it
Old Oct 2, 2011 | 03:39 PM
whiskerz's Avatar
on a 2012 I would let the dealer solve it . that said look and see if the stuff in the trunk is loose spare , jack etc. also climb in the trunk and see if you can move anything back there
Old Oct 2, 2011 | 05:10 PM
The general fixes are in the above Honda TSB links. If the car is still under warranty, then they would be covered.
Old Oct 16, 2011 | 04:01 PM
czrlaker's Avatar
Pull out the rear brake light bulb. the center one in the rear window. That's your problem, I pulled it out, the rattle is gone. Now just gotta find some kind of non-permanent putty, for sound absorption.
Old Mar 20, 2012 | 07:13 PM
TonyC2012's Avatar
So I haven't been here in a while...here's an update on my situation. I had the dealer fix it per the service bulletin in October. That seemed to work for a while. But now the rattle is back and probably worse than it was before. I took it back to the dealer and they claimed to not hear it. So I took the service guy for a ride to show him. He said the next step, if it doesn't go away, is to replace the rear deck. That seems a bit extreme, especially since it seems to be a widespread problem. I guess I'm gonna try the brake light fix and see if that works.
