rear shocks 2000 accord coupe
Old Dec 10, 2010 | 02:48 PM
jacksta's Avatar
Exclamation rear shocks 2000 accord coupe
Send help!!!!! Where can I find the top of the rear shock in my 2000 accord coupe (trunk or rear seat)? What has to be removed to get to it? Knocking sound in left rear (sounds like shock is not tight or a bushing is missing). Happens when driving and I hit most bumps. May be more obvious when turning and hitting bumps. Examined all rear linkage from underside. Everything is tight with bushings intact. Must be top side of rear shock!!!!
Old Dec 10, 2010 | 03:09 PM
I would suggest to download a 98-02 shop manual from the online manuals thread in the DIY section. It will show you how to take out either the trunk panel or the back seat to access the top of the shock.
Old Dec 13, 2010 | 10:56 AM
jacksta's Avatar
Default PAhonda
Thanks. Will do.
Old Dec 13, 2010 | 06:39 PM
Rear "bulkhead". Looks to be the "shelf" behind the rear seat,,,but you have a coupe. Section 20 of the manual will/does show the procedure.
Old Dec 13, 2010 | 07:31 PM
Honda shocks are very good shocks, but do fail. I would check the stablizer bar bushings and end links carefully to be sure that's not the problem. Much easier/cheaper than new shocks.
Old Dec 14, 2010 | 10:22 AM
jacksta's Avatar
Default poorman212
Thanks poorman. I'll check it out. You may be a poorman but you're rich in knowledge.
Old Dec 14, 2010 | 10:23 AM
jacksta's Avatar
Default TexasHonda
I'll check those bushings again. Thanks for your advice.
Andrew James
May 14, 2014 09:56 PM
ZionsWrath
Jun 20, 2009 09:33 PM
junker
Sep 27, 2008 10:59 PM
ditbu13oi
May 8, 2007 05:56 AM
