Remove and replace reflector on trunk 2011 honda accord LX-P
Hello,
I am having difficulty finding out how to remove the reflector that is embedded in the trunk lid.
As you can see by the pic, mine is cracked and water logged.
Any ideas?
Thanks
jack reflector
Moved your post to the correct forum (gen tech help), so you'd get a response. That piece probably has bolts/screws holding it in place at the edge of the trunk or from behind, where you' have to pull back the trim panel. If you get a new part, look on the part for where a bolt/screw holds it in place.
