Removing trunk tail lights??
Old Nov 26, 2010 | 09:10 AM
SaltyinNJ's Avatar
Default Removing trunk tail lights??
Hello all. I have a 04 Accord EX. How in the world do I take off the tail lights that are on the trunk? I've looked under the cloth on the inside of the trunk, and only can see one bolt. Can anyone show me or guide me in the right direction so that I can take them off and then back on? Thanks in advance everyone!
Old Nov 26, 2010 | 11:31 AM
The bumper needs to be removed first.
Old Nov 26, 2010 | 01:33 PM
SaltyinNJ's Avatar
Even for just the lights that are on the trunk?
Old Nov 26, 2010 | 03:09 PM
Unless, you are referring only to the light bulbs, or the center tail light panel; then yes, the bumper normally is removed to remove the left or right tail light assembly.
Old Nov 26, 2010 | 08:30 PM
bigdawg74's Avatar
Why would you have to remove the bumper to remove the trunk lights??
Old Nov 26, 2010 | 08:45 PM
Because there are additional nuts and screw(s) that are to be removed from the tail light assembly from the bottom, after the bumper is removed. This is not including the nuts that are removed from the trunk area, like other older Accords.
Coupe and sedan is just slightly different.
Old Nov 27, 2010 | 09:12 AM
SaltyinNJ's Avatar
Man, what a pain in the butt....
bdrumm
Oct 30, 2012 10:46 AM
roadking
Aug 15, 2011 03:39 PM
myfirstisanaccord
Apr 24, 2011 08:25 PM
Aistisval
May 20, 2007 05:00 PM
foxracing31702
Feb 10, 2007 12:01 AM
