Replace oil pump chain/ balance shaft
Old Apr 20, 2024 | 03:12 PM
kris_loehr's Avatar
Default Replace oil pump chain/ balance shaft
In changing the oil pump chain/ balance shaft I have a question that I can't find on our site or the web. As I rotated the sprocket with the chain off do I need to check the oil pump timing and how to. The back of the balance shafts have a line that might mean something.
Old Apr 21, 2024 | 10:56 AM
In the 08-10 shop manual, the chain from the crank to the oil pump does have timing marks on the oil pump sprocket. A new oil pump chain should have some different colored links or maybe marked links.
It doesn't make sense as to why the oil pump would require timing marks. Maybe to make sure the correct number of links between the crank and oil pump sprocket for tension purposes?
Honz
Apr 13, 2024 04:33 PM
Brent1990
Mar 15, 2019 05:34 PM
jeckel7234
Dec 30, 2016 01:22 PM
jgunna718
Jun 25, 2016 09:10 AM
bougie_44
Nov 27, 2011 08:22 AM
