Replacement muffler size
Old Sep 11, 2014 | 11:35 AM
cukaracha's Avatar
Default Replacement muffler size
Hello,
I'm looking to get a replacement muffler for my '94 Accord LX, and I was hoping to get some info about what "size" is right. On the product description, I see a measurement for "inlet." However, I'm not sure if that refers to diameter or length.
So my question is, do all mufflers have a standard inlet diameter? Besides that, are there any other specs that I should take note of? If it helps, I'm looking to get a Cherry Bomb Turbo (simply because it's cheap).
Thanks guys!!
Old Sep 11, 2014 | 06:38 PM
jroxz44's Avatar
Almost A Senior Member
If your going with a turbo I would get a bigger exhaust system then stock just because stock are choked up and your cramming alot of air into the motor.
To answer your question I believe stock size is 2inch but I got a full system direct fit and it works awesome for really cheap here
http://www.protuninglab.com/engine-catback-exhaust-honda-accord-1994-1997.html
You can even go cat back if your cat is good.
I really like the one I got. It has removable silencer if you like it loud. I leave mine in. It has nice throat but not real ricey sounds
Old Sep 12, 2014 | 09:01 AM
cukaracha's Avatar
I'm mostly concerned about keeping the noise of my car down, so I'm not trying to change the exhaust system. That said, which model of the Cherry Bomb would you recommend?
The previous owner had a hack job done when replacing the muffler, so basically the stock was cut off and the replacement welded on. So it looks like I'll have to have this new muffler welded on as well.
drummer1279
Mar 3, 2012 10:38 PM
crispin
Jun 21, 2011 05:55 AM
s4m222
Dec 22, 2009 12:31 PM
Curious3470
Sep 4, 2009 11:48 AM
tiffany
Apr 29, 2005 07:17 PM
