Replacing Immobilizer - couple questions
Old Sep 8, 2024 | 07:46 PM
Ih8vols's Avatar
Default Replacing Immobilizer - couple questions
I have a 2010 Accord LX-P. Car has 180k miles on it.
Started having to crank to 5-7 times before it will turn over.
Ended up taking it to the Honda dealership last week. They found “immobilizer unit is cutting in and out. Replace and reprogram keys.”
Good news is, I finally know the problem. Bad news is, the dealer said the part is backordered. Has been for a while and they don’t know when they will get one.
After researching it, I saw it’s pretty easy to replace. So, I went to the junkyard today and pulled one.
Question - do I need to have the replacement immobilizer programed?
In this video, the guy doesn’t appear to have needed to reprogram anything.
https://youtu.be/UO5kEURbkJA?si=MboYf4bsx-3pR6Sv
I switched out the parts tonight and I now have a constant green key light. I’m assuming that means it does need to be programmed but I was under the impression that the immobilizer just received the code from the transponder in the key.
Thanks!
Old Sep 8, 2024 | 09:20 PM
I think older accords maybe through 07, the immobilizer was just an antenna and the programming was in just the PCM. A quick look at the 08-10 accord, the immobilizer part you replaced has a control unit that would require programming.
Old Sep 8, 2024 | 09:32 PM
Ih8vols's Avatar
Thank you. Is that something a locksmith can usually do? Or is there a tool I can get to do it?
Old Sep 8, 2024 | 10:55 PM
A locksmith would probably be your best bet. The scanner would likely cost too much money to purchase for a one-time use.
ma221
Jul 30, 2023 02:20 AM
ChristopheRobin Byers
Sep 11, 2016 07:46 AM
cbsdd
May 16, 2014 06:38 PM
silver07exv
Dec 29, 2012 07:11 PM
MizterKewl
Feb 2, 2011 01:16 AM
