replacing motor
Old Jun 15, 2011 | 01:56 PM
accord99's Avatar
Default replacing motor
found a motor to replace my tired one. mine is a 99 honda accord 2.3 vtec 5 speed. found a 2.3 vtec out of accord with automatic. is the only difference going to be swapping flex plate to my flywheel. balance?
Old Jun 15, 2011 | 02:38 PM
The engines should be pretty much identical, except for the flywheel, clutch, pressure plate.
Old Jun 15, 2011 | 04:22 PM
piggylover1985's Avatar
Yep, take out the flex plate with 17mm 12 points socket and swap your fly wheel right over using the same bolts.
Old Jun 15, 2011 | 10:12 PM
Just to make it clear, you need to use the flywheel bolts from your old engine. The bolts from the auto-trans car will be too short.
Check whether it's the same engine. F23A1 vs. F23A4 vs. F23A5 (VTEC or ULEV or not)
mclasser
Aug 4, 2015 01:07 PM
hondababy76
Feb 20, 2013 07:36 PM
kip
Sep 3, 2012 10:08 AM
brennonm
Sep 1, 2008 10:42 AM
accord4sroy
Aug 22, 2007 11:24 AM
