Replacing Oil Pressure Switch
Old Jan 24, 2013 | 04:32 PM
fiend's Avatar
Default Replacing Oil Pressure Switch
Is it possible to replace the oil pressure switch without jacking the car up and putting it on stands? So I would be replacing it from above.
The car is a 97 Honda Accord SE non-vtec.
Thanks.
Old Jan 24, 2013 | 06:25 PM
If you have long skinny arms....you might be able to get there. The tube from the air filter to the TB has to go....then from the pass side you should be able to get a hand there???? Never tried it that way.
Old Jan 24, 2013 | 08:29 PM
fiend's Avatar
Thanks for the reply.
Is the boot replaceable? I have heard that it can rip when being removed.
Old Jan 26, 2013 | 09:54 AM
I don't see the boot listed as an item by itself...
If it does rip, I wouldn't worry about it that much.....
Old Jan 26, 2013 | 08:36 PM
fiend's Avatar
Thanks.
Do you recommend using an Honda oil pressure switch? Looks like they cost $20 from the dealer. Also what tape or sealant should I use when fitting the new one?
Old Jan 27, 2013 | 07:51 AM
For $20 I'd just buy the oem one. Did you check hondaautomotiveparts.com? They are usually a bit cheaper and I have always been able to get my local dealer to match their prices. I found that local car dealer's prices are very negotiable. But even $20 isnt bad.
I would just put some teflon tape on it.
Old Jan 27, 2013 | 11:27 AM
When you get the new one, inspect the threads. Sometimes they have sealant already on them, if not as Rice suggested a wrap or two of teflon tape and your will be good to go.
usedcarman
Feb 22, 2024 03:48 AM
MGF 1996 Accord
Dec 15, 2014 01:31 PM
swells244
Jul 9, 2010 08:28 PM
freezerman
Jul 3, 2009 09:40 PM
kcobra
Aug 7, 2006 10:39 PM
