replacing rear wheel well
Old May 16, 2012 | 07:39 PM
95bessy's Avatar
Exclamation replacing rear wheel well
Hi, I have a 95 Accord its the V6 model, I'm wondering if the wheel wells on the 4 cylinder model are the same shape and size?
Or would I have to specifially from a V6 model
Thanks for the help
Old May 16, 2012 | 07:51 PM
crispin's Avatar
Headers, Intake, or Exhaust??
Rear Wheel Well, do you mean rear quarter panel?
Old May 16, 2012 | 07:53 PM
crispin's Avatar
I am going to assume the following
1)You posted this is the wrong section
2)You are talking about a rear patch panel which is the outside arch of the rear quarter panel.
If those assumptions are correct, then yes the rear patch panel should be the same on the 4 cyl or 6 cyl
Old May 17, 2012 | 10:36 AM
95bessy's Avatar
Default @crispin
sorry, i'm new to these forums.. still learning and yes your asssumtions are correct i am looking to replace the rear quarter panel because mine are rusted right down to the rear door leading to the rockers.
So I can take a rear quarter off of a 95 4 cylinder and put it onto my 6 cylinder and they will match up
Old May 17, 2012 | 10:59 AM
crispin's Avatar
yes the front ones may be different (as some years have a longer hood for the V6) but the rears are the same on all years.
Good luck!
Old May 18, 2012 | 01:07 AM
I'll move this over to General Tech.
I know in the FRONT end the V6 & 4-cyl cars are different. Not sure about the rear quarter panels.
Old May 18, 2012 | 08:46 PM
95bessy's Avatar
Good luck!
Thanks for the help!
I knew the front were different length just wasn't sure of the rear
faosh
Mar 28, 2009 02:59 AM
PAhonda
Jan 20, 2009 10:43 PM
blackonblack
Feb 7, 2008 11:17 PM
Yorty
Jan 7, 2008 09:54 AM
trukid21
May 11, 2007 03:58 PM
