reverse lights not working
Old Dec 2, 2010 | 01:46 PM
redbaron131's Avatar
Question reverse lights not working
I have checked both lights and fuses they are good. cant figure it out
2005 HONDA ACCORD EX 2.4L MFI DOHC 4CYL Auto
Old Dec 2, 2010 | 04:26 PM
Do you have a volt meter? Unplug one of the reverse light bulbs and test the bulb socket.
Does the blk wire have continuity to ground? Does the non-blk wire have 12V to body ground when the car is in reverse? You will need an assistant to do this one (unless the reverse lights turn on when the car is not running?)
Old Dec 2, 2010 | 05:42 PM
#20 on the trans is the "position sensor". I guess that tells what gear it's in? Check for flaky electrical connections. But I guess if that was flaky, you'd get a flashing D4 lamp to indicate there's a problem.
I looked for a separate simple switch for reverse, like you usually have on a manual trans. Didn't find one, but that might just mean I didn't look hard enough.
csh217
Apr 30, 2013 09:03 PM
naimperez
Oct 2, 2011 07:01 PM
rogerthat23
Apr 11, 2009 10:32 PM
Stoenr
Jan 29, 2009 03:24 PM
arunsam3000
Mar 6, 2007 01:40 PM
