Rotating tires on '00 Accord EX
I'm new to Honda cars and am trying to rotate the tires on the driver's side. I have directional tires so I'm just going front to back and vice versa. Front tire came off as planned. Back tire is stuck for some reason. All 5 lugs are off and the tire spins but will not come off.
I looked in the owner's manual and found nothing. Any help? Thanks. N Headley |
RE: Rotating tires on '00 Accord EX
Are you sure that the E-brake is off? Do the lugs appear rusty? If so, tap with a rubber hammer on the backside of the wheels as you rotate them. It's damn sure worth a try and costs nothing.
Yeah, I checked the e brake and the lugs are fine. My problem was that I was being extremely cautious with my new car. I just gave it a little kick at the bottom of the tire and knocked it loose. Problem solved...tires rotated.
Thanks for your help though. |
ORIGINAL: headleyn Yeah, I checked the e brake and the lugs are fine. My problem was that I was being extremely cautious with my new car. I just gave it a little kick at the bottom of the tire and knocked it loose. Problem solved...tires rotated. Thanks for your help though. Glad you got it squared away. |
Hey Tex...I was gonna suggest that you use your Magic Wizard Wand , but the guy got his job done without either one of us...
WheelBrokerAng |
while working as a tech, id say 1 out of every 5 or so cars had the wheels gaulded on...some, especially steelies..i had to beat with a 5 lb sledge to get them off!
Actually this is my favorite trick - back in the Israeli Army i was a martial arts instructor - theres a kick called Uromovashi - kindof 360 degree high kick...so
i lift the car up if the tire doesnt come on - i just make a nice kick - works 101%! [8D] Also - its always good to balance the tires when you rotate them |
