rough starts
Old Jan 25, 2023 | 10:32 AM
jessecolter's Avatar
Default rough starts
Of my three 93 Accords, two of them have this issue:
Sluggish cold start, two pistons get going, then 3, then purrrrr.. takes about 10 seconds at worst.
Sluggish cold start, just some extra engine turns before it immediately runs right. Slight smell of gas when this happens.
Just about everything has been done except injectors, that is my theory, anyone?
Old Jan 25, 2023 | 11:16 AM
Try this. Before a cold start, turn the key to the II position, but don't try to start the car. Wait until the check engine light turns off after the 2 second bulb check. Turn the key off and repeat for a total of 3 times, then try to start the car. This is allowing the fuel pump to pressure up the fuel rail. Let us know if the cars start up smoother.
Old Jan 27, 2023 | 11:01 AM
Yeah that was totally it on both accounts, dang.
If I prime the fuel they fire right up.
Old Jan 28, 2023 | 09:42 AM
Is there anything this tells us like it might like new injectors?
Old Jan 29, 2023 | 09:02 PM
It is probably the check valve in the fuel pump, where the fuel system doesn't hold pressure.
MessAround
Nov 29, 2012 04:43 AM
Fubz
Nov 10, 2012 12:54 AM
Paul Ankers
May 26, 2012 08:15 AM
Mrheat
Dec 13, 2007 03:34 PM
AccordEX
Dec 4, 2006 02:09 AM
