Cold start trouble
Old Dec 13, 2007 | 03:12 PM
Mrheat's Avatar
Default Cold start trouble
I recently moved from Las Vegas to northern Utah, so I've gone from warm to very cold and I think the temperature has brought out a new problem in my 92 Accord. On a cold start it seems like it is taking awhile for all 4 cylinders to start firing. Its a consistent roughness that lasts from 5-20 seconds. After a little convincing it runs perfectly and there are no problems after that. The car has almost new ngk plugs and wires and there isn't a problem when its warmed up. I appreciate any ideas any of you may have!
Old Dec 13, 2007 | 03:15 PM
sir_nasty's Avatar
Default RE: Cold start trouble
are you saying that once it starts running it's rough for 5-20 seconds or it takes 5-20 seconds of turning over to start?
either way if it's alleviated once it's warm then a block heater should help
Old Dec 13, 2007 | 03:28 PM
falkore24's Avatar
Nate, is it possible that his HITV is messed up and not holding the idle high enough for the initial start? The 5-20 seconds thing is why I'm thinking of the high idle. Also, a rough idle usually disappears if you give it a little gas.
Old Dec 13, 2007 | 03:34 PM
Mrheat's Avatar
The car starts right up, its just rough. The idle speed seems ok, but again, its rough.
Isengard2216
Nov 28, 2014 11:55 AM
RyanHostetler
Nov 14, 2013 08:06 PM
gasface11
Jul 11, 2012 12:33 PM
dmalay1
Jul 6, 2009 02:36 PM
thunder_x
Oct 15, 2006 10:33 PM
