Screw keeps coming out of shift stick
Old Oct 1, 2018 | 12:00 PM
rockhoundrob's Avatar
Default Screw keeps coming out of shift stick
1998 Accord LX.- AUTO- trans.
The shift between the seat has a screw on the handle that comes out once every few months. When I look at it, the screw comes out on the driver side.
On the passenger side, there also a hole. Is there a cap that goes there? or is there another screw that also goes on on the passenger side?
I am thinking about taking the screw out on the driver side and add a dab of "Lock-tite" just to keep it form coming out again. This locktite is not permament, but just to keep it from working loose.
Any suggestions?
Old Oct 1, 2018 | 12:12 PM
Eran Teitelbaum's Avatar
A 243 loctite won’t do any harm.
Old Oct 1, 2018 | 03:26 PM
The Toecutter's Avatar
Any suggestions?
Do you mean you're going to use "screw tite" (a light weight version of blue loctite). I think that should work very well, and won't be a permanent, like regular blue loctite would be.
Old Oct 1, 2018 | 04:16 PM
blue loctite isn't permanent, the green one is.
Old Oct 2, 2018 | 06:02 AM
dgp1961's Avatar
Almost A Senior Member
Loctite comes in different strengths read bottle and be sure you're not using a permanent one that's all.
Old Oct 2, 2018 | 06:14 AM
Parts drawing shows both screws identical. So you could get another screw the same (even from a hardware store) for the other side. Some Loctite would still be good...
Old Oct 2, 2018 | 06:17 AM
dgp1961's Avatar
Not to change the subject but I always have the same issue with the damn little screw in the Honda key/fob. They have some "blue" thread sealer on them also but always back out.
Old Oct 2, 2018 | 07:51 AM
Thanks for the inputs... I decided to get an extra screw from the junkyard. Then I used teflon tape on the threads.
If you don't hear from me again, then that means problem is solved. If the screws come out again, then I will try "blue tite".
AMP-Ninja
Jun 15, 2011 07:08 PM
consumed24
May 23, 2008 11:28 AM
sarmac415
Dec 15, 2007 02:09 AM
GalenMan679
Nov 12, 2007 05:05 PM
reeling
Aug 15, 2007 05:06 PM
