Seafoam tune up
I plan on using a can of seafoam today to help tune up my car. I have never used this product before and Im looking for a little insight before I use it. Im want to get the best use that I canout of it. I want to put it in the Oil, Intake, and Gas. Is there a set amount that I need to distribute into each one? I have only one can.
Are the results they state at the end of the clip even true? sumpump, let us know how it helps out your vehicle. I've never heard of the stuff but it sounds like a bit of a gimmick.
i ran some through my car as far as the results- it ran a bit better but i dont know exactly how long it takes for actual noticeable results.smokes like crazy witch is supposed to be the break down of carbon throughout your intake, motor, and exhaust.but the bit of extra power you feel rite after you put it in is probably because it works as an octane buster.not sure about that but its my theory.its only like 9 bucks for a 16oz can so i figured screw it might as well try it
if you want the best results run it through your break booster.
I don't feel like typing this all over again read this... https://www.hondaaccordforum.com/for...503#post196503 |
