Serpentine / alternator belt how do I tighten the belt?
Old Nov 18, 2013 | 10:20 AM
Imonlybonnie's Avatar
Default Serpentine / alternator belt how do I tighten the belt?
I had the serpentine belt replaced by a mechanic he said the belt tensioner was missing but Ives tried to research it and call the dealership and the dealership said they there isn't a belt tensioner for my car. How do I tighten the serpentine / alternator belt ?? People that have dealt with this before or know exactly what I'm talking about please comment show me a image or something? If you have no clue please don't waste my time with your opinion. I need facts from people that have done it themselves. I have a 1993 honda accord 10th anniversary.
Old Nov 18, 2013 | 11:28 AM
There is no serpentine belt, but an adjustable alternator position assembly.
You must loosen alternator through bolt at engine mount, loosen alternator lock nut on through bolt underneath alternator, and then use adjustment mechanism visible at front end of alternator to tighten the belt to adequate tension, usually 1/2" deflection w/ 20 lbs force (estimated).
If you have no clue what to do, it's usually better to be polite for best results and general order on the forum.
Old Nov 18, 2013 | 11:32 AM
Here are some images with some notes I included. The second image is the belt deflection measure done if you didn't have a belt tension gauge.
Attached Thumbnails Serpentine / alternator belt how do I tighten the belt?-adjusting-alternator-belt.jpg   Serpentine / alternator belt how do I tighten the belt?-belt-deflection-without-belt-tension-gauge.jpg
Old Nov 18, 2013 | 11:48 AM
Don't you tighten the alternator belt by swinging the alternator itself in & out on it's mounts?
(hah, the other guys beat me to it)
john_pyro
Jan 10, 2013 11:10 AM
Michelle
Mar 2, 2012 06:36 AM
aking
Apr 4, 2011 11:19 AM
ahmad89
Apr 23, 2010 03:43 PM
Amtrak288
Dec 29, 2007 01:18 PM
