Servicing @ 105,000 miles?
Old Mar 29, 2012 | 07:28 PM
powersoul's Avatar
Question Servicing @ 105,000 miles?
Hi,
I am new here. I just purchased a 2002 Honda Accord EX V6 @ around 103K a month ago. I read in the user manual that the Honda should be serviced at around 105k. Is this a good idea? The car is 10 years old but runs really smooth. I talked to the previous owner who said that he did basic servicing to the car before selling it to me.
What should I do?
Thanks in advance!
Old Mar 29, 2012 | 07:59 PM
Do you know if the timing belt has been replaced? If not I would get it done as soon as you can. Its a somewhat expensive service to have done, but if the timing belt fails the engine will most likely be destroyed and cause thousands of dollars worth of damage.
Old Mar 29, 2012 | 08:03 PM
powersoul's Avatar
I can call the owner tomorrow and ask him if he replaced the timing belt. I checked all the fluids and they all are above the minimum threshold. Should I also worry about the spark plugs? I am not a car person, I am talking out of the manual.
Also, where would you recommend I get my service done? I have heard stories that Honda dealers overcharge for no reason.
Old Mar 29, 2012 | 08:12 PM
I know the Honda dealer close to me has a pretty high hourly rate($100+ an hour)
Do you have a local mechanic you trust? They usually charge about half what the dealer charges.
Spark plugs last a long time, but if you have no idea when the last time they were replaced it isn't a bad idea to just replace them as they aren't that expensive.
Old Mar 29, 2012 | 09:33 PM
UhOh's Avatar
Originally Posted by powersoul
Should I also worry about the spark plugs? I am not a car person ...
Buy the iridium tip spark plugs ($8) and you'll 'never' have to replace them again - it's an easy job
to do for a new guy and should give you some car work confidence...
If prior owner only did routine maintenace that probably didn't include timing belt.
With TB replacement, some models replace the water pump too - 'cuz all the labor's been done.
Dealer'll charge $800 - 900 (would be done right - but, not advocating either way really).
Old Mar 29, 2012 | 10:17 PM
I am not advocating dealership or independent either. However, sometimes you may end up with a noise or vibration (that never was there before) after a timing belt change by an independent who does not specialize in Hondas.
Old Mar 30, 2012 | 01:20 PM
powersoul's Avatar
I tried contacting the owner. He is out of town - is there any way I can find out if the timing belt needs replacement?
I don't know any independent mechanics around me, I just moved into this country a few months back.
Old Mar 30, 2012 | 01:29 PM
The general rule of thumb is if you can still read the writing on the belt then it has probably been replace recently. But I would still consider replacing it.
Also some dealers will put a sticker on the cover saying when it was changed.
Old Mar 30, 2012 | 06:21 PM
powersoul's Avatar
Ok, so I talked to the owner and he never changed the timing belt because he didn't have to. He said that the Honda dealer never recommended that. So I am guessing I will wait till the car reached 105K and then get the scheduled maintenance done on it which includes replacing the timing belt. Good idea?
Also, I am having trouble finding the transmission fluid dipstick? Where is it? The car is auto.
Old Mar 30, 2012 | 06:30 PM
For the V6, the area behind the battery. See attached.
