Sizing & Spring Loaded Constant Tension Hose Clamps???
Old Apr 24, 2018 | 08:57 PM
windnsalsa's Avatar
Default Sizing & Spring Loaded Constant Tension Hose Clamps???
Not severe but urgency in timing [needing to get the car running tomorow--Wednesday]...
A few questions regarding sizing of spring loaded constant tension hose clamps. Forums research seems to conclude to try to use new spring clamps and avoid using worm clamps. I have decided on using spring clamps. Very tough to find locally, but found some at a newly opened Ace Hardware. I thought this small project is completely straight foward but reading a bit on the net and trying to find them locally have been tough. Dealer here in San Jose was asking $11/each.
I am replacing a heater coolant hose that is 5/8" inch inside diameter and 15/16" outside diameter [same as factory]. If we want the "correct" tension, would we want to use spring clamps of size 15/16" or 7/8"?
The damaged hose has strong impressions from the factory clamps [seems to be 7/8" clamps]. I bought 7/8, 15/16 clamps. Which size do you think is best/correct? Wanting to minimize risk of leaking [if a bit loose] or gashed hose or plastic water inlet valve connector [if too tight]. I am leaning towards 7/8 [in between ID and OD].
Thanks
Old Apr 24, 2018 | 09:21 PM
Online Honda dealer show Honda Part No.: 19513-PE0-003 Clamp, Water Hose (21.7mm) (Chuo Spring).
Based on that, the 7/8" clamp should be closer to the OEM clamp.
FRACTION TO DECIMAL AND MM TABLE
Old Apr 24, 2018 | 10:05 PM
windnsalsa's Avatar
hmm...but the hose in this diagram is connects to the waterpump. Mine is heater hose from water inlet valve to the block/manifold underneath the distributor. Wondering if same size hose???
Old Apr 24, 2018 | 10:13 PM
You may be looking at the wrong diagram. What I listed is for the following:
https://www.hondapartsnow.com/parts-...ter-valve.html
Old Apr 25, 2018 | 01:18 AM
windnsalsa's Avatar
Yea, hondapartscheap has a waterpump diagram. Your diagram is correct.
It was too difficult to slide the 7/8 when hose was over the fitting. And still difficult even after removing the distributor to get better access. Afterwards, I changed to the 15/16 and was very successful. For some reason, it was harder on the plastic valve end. I had to use a bit of soap to finish sliding the clamp on that end.
This should have been a straight forward project. The more I read about things, the more detailed the project became. Probably should have reused the old factory clamps, which are wider, more robust and easier to secure with pliers. Several have mentioned that these spring clamps should not be reused. I'll be keeping them for backups. I tried 3-4 different type of pliers. Of course, would have been easier more dedicated pliers. The worm clamps would have been much easier.
Then, I discovered the hose from dealer had a smaller OD, which probably would have been an issue with the original clamps, which I was planning to re-use before finally finding some aftermarket ones from Ace. But, I returned that hose.
I bought a 10ft non-molded heater hose at Lowes and was planning to use it because it was cheaper than the molded one from dealer and auto parts store, would have hoses available for other cars at the house, dealer was OOS at the time. I returned them as well because I observed using it without being molded and thus not at preferrable angle to the fittings would place some angling pressure on the hose and the connectors as well as having the hose touching some plastic wiring housing. Also, the OD was similarly smaller as that from the dealer.
I ended up using the molded one from Autozone which had same OD as that of the original one.
Because the car belongs to my mother, I didn't feel comfortable with the straight hose, as I won't be around to monitor it. If it were mine, I would have made use of the Lowes hose.
Old Apr 25, 2018 | 02:17 PM
The Toecutter's Avatar
I think you've kind of answered your own question. Use the molded hose, and your old squeeze clamps, as they are sized correctly for the hose and it's fittings.
Old Apr 25, 2018 | 05:32 PM
windnsalsa's Avatar
But it has been disconcerting to discover various little potential issues such as the replacement part from the dealer had a smaller OD than the original. Then, using these used clamps may cause leaks.
Old Apr 25, 2018 | 06:07 PM
Reusing the clamps will not cause leaks if you get the new hose installed all the way up on the radiator and water pump fittings.
Old Apr 25, 2018 | 08:03 PM
windnsalsa's Avatar
That has been my feelings overall. I had planned to re-use them until I visited the last local store and found some aftermarket ones, albeit seemingly inferior ones. Ridiculous dealer here was charging $11 for each clamp, over half the price of their hose!
Thanks, project is completed.
Old Apr 27, 2018 | 01:22 PM
That's just dealer pricing. My son went to the dealer to get a lug stud and nut for his 08 Civic. The dealer wanted 10.99 for the stud, and 8.99 for the lug nut. The kicker was both had to be ordered. He stopped by O'Reilly's on his way back and got both for 6 bucks.
vet67coupe
Aug 8, 2013 11:18 PM
cybersyntatics
Aug 28, 2012 11:59 PM
oneloudskunk
Mar 19, 2012 11:28 AM
el toro
Nov 1, 2006 09:20 PM
HondaLawgik
May 3, 2006 02:32 AM
