Slave cylinder squeak
Old Sep 14, 2013 | 02:21 PM
PGRNPA's Avatar
Default Slave cylinder squeak
Hi all, new to the forum and this has been a terrific source of information as I just completed a clutch flush. However, I now have a squeak coming from the slave cylinder when depressing the pedal. Any ideas? Thanks so much!
Jeff
Old Sep 14, 2013 | 05:13 PM
Try some anti-seize on the end of the piston of the slave cylinder that pushes the shift fork. You may have to unbolt the slave cylinder from the transmission to do this.
Old Sep 15, 2013 | 02:08 PM
If that doesn't help, there's another ball/socket which is the pivot point of the clutch throw-out fork. That one is inside the bellhousing and difficult to reach unless you take the transmission out of the car.
Buktheng
Feb 11, 2008 06:31 PM
Buktheng
Jan 27, 2008 06:20 PM
watut
Mar 3, 2007 02:47 PM
gonecrazy
Oct 12, 2005 11:57 PM
gonecrazy
