Small Electrical Issues - 03 4 cylinder EX
Bear with me... I'm on my phone. My dad gave me his Accord when the head went bad. 307,000 miles. Fixed all that. Car is perfect except some minor things.
I know there are tons of console issues - but mine don't seem as extreme and HAVE to be something small. Front Turn Signals My front signals only work when unlocking the car. Otherwise they are always on. This causes that crazy hyper flash - since they have decided to not flash. Tail lights - fixed but might havery caused issues below My tail lights were not working at all. Until I unplugged the accessory plugin/ cigarette lighter next to the "This is not an ashtray" lol Console Lights The only thing that doesn't work are the symbols on the buttons. The climate control activated lights work (the little green and yellow dots when you press for example "Dual".). My radio back light also works just fine. Could the accessory plugin going out cause this? CD Changer: Button on Radio doesn't do anything. Won't switch to CD or eject what's in there. I'm assuming the changer needs replaced. Wanted to mention it in case that was an issue causing the above issues. But I don't use it. Thank you for your time. Edit: Just realized transmission Lights next to the shift also do not work. My dad did say those haven't worked for a long time (pre-console lights) |
What happens to both front and rear turn signal bulbs when you turn on the hazards?
Originally Posted by PAhonda
(Post 357487)
2 Attachment(s)
1. Have you check both front bulbs to see if they are okay? Each bulb is dual filament and serve dual purpose as a turn signal and a side marker.
2. Which symbols on the buttons don't work? Are they shown in the attached image? Fan control buttons? |
(Post 357489)
2. Which symbols on the buttons don't work? Are they shown in the attached image? Fan control buttons? 2. Yes, for example the fan control don't light up. Neither do the words (which I think they're supposed to (Auto, Dual, the little car for air circulation, etc). I also thought the hazard button symbol at the top should glow red, but it's dark as well. The little circles above the symbols do light up, though. Edit: this is where I wasn't sure if me unplugging the accessory plugin caused the circuit to short and I need to order a new one to complete the circuit. |
2 Attachment(s)
Also - took a photo http://imgur.com/ccyCGcn
http://imgur.com/lY8iXD3 Attachment 24672 Attachment 24673 |
The front bulbs can possibly be both bad.
When you use the key fob, that is for the security system. The security system uses the taillight relay to provide power to and flash the front bulbs via separate Red/Blk wires and to the bulb filament for the side marker. -- Essentially the side marker flashes. For the front turn signals, it uses the turn signal/hazard relay to provide power and flash the front bulbs via different wires (Red/Blu and Brn) to the different bulb filament for the turn signals. The climate control buttons may not be related. I will have think about and get back to that, maybe tomorrow. :) |
(Post 357493)
When you use the key fob, that is for the security system. The security system uses the taillight relay to provide power to and flash the front bulbs via separate Red/Blk wires and to the bulb filament for the side marker. -- Essentially the side marker flashes. For the front turn signals, it uses the turn signal/hazard relay to provide power and flash the front bulbs via different wires (Red/Blu and Brn) to the different bulb filament for the turn signals. The climate control buttons may not be related. I will have to get back to that. |
Sylvania bulb guide list 1157A.
(Post 357495)
