Smoke from Radiator Cap
Old Jan 8, 2008 | 11:36 PM
  #21
patpatpat's Avatar
Default RE: Smoke from Radiator Cap
So after all the troubleshooting, it is the thermoswitch correct? Someone please confirm! I just want to make sure before I head out to the stealership, oops dealership again. FYI, the switch costs $44.
Yea, with the fan constantly on, no more steam! yay! also, the acceleration response is a bit jerky, not as smooth, just something I noticed.
Old Jan 9, 2008 | 06:51 PM
  #22
Are you jumpering the thermoswitch A (behind the distributor on thermostat housing)? If yes, then themoswitch A is the problem.
Old Jan 9, 2008 | 07:14 PM
  #23
HondatechAV6's Avatar
yep, replace that thermoswitch. don't leave the terminals jumped permanently since you will overheat the fans and destroy them and the radiator fan shrouds.
after you fix that, lets work on the jerky problem. if it's still there describe it exactly and in better detail?
Old Jan 9, 2008 | 10:04 PM
  #24
patpatpat's Avatar
I got the switch, I will replace it tomorrow. I will keep you all updated.
Old Jan 10, 2008 | 04:09 PM
  #25
patpatpat's Avatar
I replaced with a new thermoswitch. The one behind the distributor and closer to the firewall. I let it idle to engine operating temp. Fans didnt come on at 52*F outside temp. Now both upper and lower hoses feel hot. No steam from the radiator.
However, the fans are not coming on. I dont want to drive around and risk it. It would be bad news if the fans dont come on during stop-and-go.
Hmmm....
Old Jan 10, 2008 | 06:15 PM
  #26
hold the engine rpm around 3000 rpm until the fans come on. the engine may not get hot enough at idle.
Old Jan 10, 2008 | 09:07 PM
  #27
ORIGINAL: HondatechAV6
no, not refresh. lets talk about what the thermoswitch does.
the thermoswitch is just a temperature switch. when it's gets hot enough the switch closes and the fans come on.
if your telling me the fans never come on i'd think something is wrong with this particular thermoswitch since it's a fairly common failure item. by jumping the two terminals together you are forcing the fans to run as if it was the switch normally turning them on. so if the fans come on you found the problem - replace that thermoswitch.
**This is the way that I was told to check out this kind of problem also..Good heads up HondaTech**
Old Jan 10, 2008 | 11:36 PM
  #28
patpatpat's Avatar
O yea!!! I am pretty sure it fixed the problem!!! The fans don't come on, but the lower radiator hose is much hotter than before now. It is able to circulate the coolant around, which cools the engine better. Outside temp 44*F
So the thermoswitch controls the fan and the thermostat?
Old Jan 11, 2008 | 12:12 AM
  #29
nafango2's Avatar
no, thermostat is a purely mechanical device, simply a valve operated by a wax pellet.
Old Jan 11, 2008 | 01:02 AM
  #30
patpatpat's Avatar
ORIGINAL: nafango2
Thats what I thought too. But the lower radiator hose is much hotter than before after I put in a new thermoswitch.
